WinAPI Problem: Fehler beim erzeugen von Prozessen...
Hallo Leute...
Eigentlich ist die Anwendung sehr klein und für nen Profi vermutlich nen Klacks, aber irgendetwas mache ich wohl einfach falsch... ich bin ein totaler Newbee was C++ angeht, bitte also Nachsicht walten lassen und das Erschießungskommando erstmal nur mit Gummigeschossen schießen lassen ;)
Das hier ist mein C++ Code:
#include <windows.h>
#include <stdlib.h>
#include <stdio.h>
#include "resources.h"
HINSTANCE hInst;
LRESULT CALLBACK WindProcedure(HWND hWnd, UINT Msg, WPARAM wParam, LPARAM lParam);
int deskBreite = GetSystemMetrics(SM_CXSCREEN);
int deskHoehe = GetSystemMetrics(SM_CYSCREEN);
int winBreite = 410;
int winHoehe = 130;
// OpenCommands //
CHAR *cmd_stop = "xampp_stop.exe";
CHAR *cmd_start = "xampp_start.exe";
CHAR *cmd_iexplorer = "start iexplore.exe \"localhost/sales_presenter\"";
// Integer defining how long to wait for process at max
int waitTime = 50000;
int xpos = (int) ((deskBreite/2) - (winBreite/2));
int ypos = (int) ((deskHoehe/2) - (winHoehe/2));
INT WINAPI WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance,
                   LPSTR lpCmdLine, int nCmdShow)
    WNDCLASSEX  WndCls;
    static char szAppName[] = "Presenter";
    MSG         Msg;
	HICON hIcon = LoadIcon(hInstance, MAKEINTRESOURCE(101));
	hInst       		 = hInstance;
    WndCls.cbSize        = sizeof(WndCls);
    WndCls.style         = CS_OWNDC | CS_VREDRAW | CS_HREDRAW;
    WndCls.lpfnWndProc   = WindProcedure;
    WndCls.cbClsExtra    = 0;
    WndCls.cbWndExtra    = 0;
    WndCls.hInstance     = hInst;
    WndCls.hIcon         = hIcon;
    WndCls.hCursor       = LoadCursor(hInstance, IDC_ARROW);
    WndCls.hbrBackground = (HBRUSH)GetStockObject(WHITE_BRUSH);
    WndCls.lpszMenuName  = NULL;
    WndCls.lpszClassName = szAppName;
    WndCls.hIconSm       = hIcon;
    RegisterClassEx(&WndCls);
    CreateWindowEx(WS_EX_OVERLAPPEDWINDOW,
                          szAppName,
                          "Presenter is starting...",
                          WS_SYSMENU | WS_VISIBLE,
                          xpos,
                          ypos,
                          winBreite,
                          winHoehe,
                          NULL,
                          NULL,
                          hInstance,
                          NULL);
    while( GetMessage(&Msg, NULL, 0, 0) )
        TranslateMessage(&Msg);
        DispatchMessage( &Msg);
    return static_cast<int>(Msg.wParam);
    HDC hDC, MemDCBmpImg;
    PAINTSTRUCT Ps;
    HBITMAP bmpImg;
    switch(Msg){
		case WM_DESTROY:
		    PostQuitMessage(WM_QUIT);
		break;
		case WM_PAINT:
			hDC = BeginPaint(hWnd, &Ps);
			// Load the bitmap from the resource
			bmpImg = LoadBitmap(hInst, MAKEINTRESOURCE(102));
			// Create a memory device compatible with the above DC variable
			MemDCBmpImg = CreateCompatibleDC(hDC);
				 // Select the new bitmap
				 SelectObject(MemDCBmpImg, bmpImg);
			// Copy the bits from the memory DC into the current dc
			BitBlt(hDC, 0, 0, 400, 94, MemDCBmpImg, 0, 0, SRCCOPY);
			// Restore the old bitmap
			DeleteDC(MemDCBmpImg);
			DeleteObject(bmpImg);
			EndPaint(hWnd, &Ps);
			// Handles for process and processinfos
			STARTUPINFO si;
			PROCESS_INFORMATION pi;
			STARTUPINFO si2;
			PROCESS_INFORMATION pi2;
			STARTUPINFO si3;
			PROCESS_INFORMATION pi3;
			STARTUPINFO si4;
			PROCESS_INFORMATION pi4;
			printf("Trying to create process xampp_stop!");
			if(!CreateProcess(NULL, cmd_stop, NULL, NULL, FALSE, 0, NULL, NULL, &si, π)){
				printf("Process xampp_stop could not be created!");
				return 0;
			WaitForSingleObject(π, waitTime);
			CloseHandle( pi.hProcess );
			CloseHandle( pi.hThread );
			printf("Trying to create process xampp_start!");
			if(!CreateProcess(NULL, cmd_start, NULL, NULL, FALSE, 0, NULL, NULL, &si2, &pi2)){
				printf("Process xampp_start could not be created!");
				return 0;
			WaitForSingleObject(&pi2, waitTime);
			CloseHandle( pi2.hProcess );
			CloseHandle( pi2.hThread );
			printf("Trying to create process ie!");
			if(!CreateProcess(NULL, cmd_iexplorer, NULL, NULL, FALSE, 0, NULL, NULL, &si3, &pi3)){
				printf("Process ie could not be created!");
				return 0;
			} else {
				printf("IE-Process was created!");
			WaitForSingleObject(&pi3, INFINITE);
			CloseHandle( pi3.hProcess );
			CloseHandle( pi3.hThread );
			if(!CreateProcess(NULL, cmd_stop, NULL, NULL, FALSE, 0, NULL, NULL, &si4, &pi4)){
				return 0;
			WaitForSingleObject(&pi3, waitTime);
			CloseHandle( pi4.hProcess );
			CloseHandle( pi4.hThread );
			// xamp should be offline, now close the application
			exit(0);
		break;
		default: return DefWindowProc(hWnd, Msg, wParam, lParam);
    return 0;
Was ich damit vor habe:
1.) Zeige einen Splash-Screen mit einem Bild. -> Funzt
2.) Öffne eine EXE namens "xampp_stop.exe", die im gleichen Verzeichnis liegen wird wie die erzeugte exe. -> Diese schließt einen Xampp, falls dieser geöffnet ist.
3.) Öffne die EXE namenes "xampp_start.exe", die ebenfalls im gleichen Verzeichnis liegen wird wie die erzeugte exe. -> Diese öffnet den Xampp (wieder).
4.) Öffne den InternetExplorer und öffne eine bestimmte URL. (die lokal liegt)
5.) Warte bis IE geschlossen wird und starte dann "xampp_stop.exe".
6.) Wenn xampp_stop.exe fertig is, schließe die Anwendung.
Wichtig dabei ist, dass der XAMPP ein bißchen Zeit braucht um runter oder hochzufahren und die Anwendung deshalb auf ihn warten muss, bevor der nächste Schritt stattfindet.
Kompilieren tut das ganze, ich bekomme auch den Splash-Screen angezeigt, leider scheinen die Dateien aber nicht aufgerufen zu werden.
Als Ausgabe bekomme ich: "Trying to create process xampp_stop!Process xampp_stop could not be created!"... scheint also was mit der Process-Erstellung schiefzulaufen... (das ist der erste Processaufruf, nicht der letzte, soweit ich feststellen konnte)
Weiß jemand was ich falsch mache?
Vielen lieben Dank im Voraus an alle die etwas antworten / versuchen mir zu helfen / helfen!
*Fuchur*
PS: Ein kleiner Bug ist beim letzten mal Warten auf den Prozess... da muss natürlich &pi4 rein... macht aber keinen Unterschied fürs Problem.
