Ich habe folgendes Testprogramm geschrieben!/*
import java.awt.*;
public class Test
public static void main(String[] args)
Frame wnd = new Frame("Test");
wnd.setSize(400,300);
wnd.setVisible(true);
[/PHP]
jetzt bekomme ich beim ausführen!!! compil. geht ohne Probleme entweder die Fehlermeldung
Exception in thread "main" java.lang.NoClassDefFoundError: C:\Test
oder wenn ich z.B. JOE verwende um mein kleines Programm zu starten
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION occurred at PC=0x6D08723A
Function=AWTIsHeadless+0x11B9
Library=D:\j2sdk1.4.0_01\jre\bin\awt.dll
Current Java thread:
at sun.awt.windows.WToolkit.init(Native Method)
at sun.awt.windows.WToolkit.run(WToolkit.java:209)
at java.lang.Thread.run(Thread.java:536)
Dynamic libraries:
0x00400000 - 0x00406000 D:\J2SDK1~1.0_0\bin\java.exe
0x77880000 - 0x77901000 C:\WINNT\System32\ntdll.dll
0x77DA0000 - 0x77DFB000 C:\WINNT\system32\ADVAPI32.dll
0x77E70000 - 0x77F32000 C:\WINNT\system32\KERNEL32.DLL
0x77D30000 - 0x77DA0000 C:\WINNT\system32\RPCRT4.DLL
0x78000000 - 0x78046000 C:\WINNT\system32\MSVCRT.dll
0x6D330000 - 0x6D445000 D:\J2SDK1~1.0_0\jre\bin\client\jvm.dll
0x77E00000 - 0x77E64000 C:\WINNT\system32\USER32.dll
0x77F40000 - 0x77F7C000 C:\WINNT\system32\GDI32.DLL
0x77540000 - 0x77571000 C:\WINNT\System32\WINMM.dll
0x6BC00000 - 0x6BC14000 C:\WINNT\System32\snd930.dll
0x6D1D0000 - 0x6D1D7000 D:\J2SDK1~1.0_0\jre\bin\hpi.dll
0x6D300000 - 0x6D30D000 D:\J2SDK1~1.0_0\jre\bin\verify.dll
0x6D210000 - 0x6D228000 D:\J2SDK1~1.0_0\jre\bin\java.dll
0x6D320000 - 0x6D32D000 D:\J2SDK1~1.0_0\jre\bin\zip.dll
0x6D000000 - 0x6D0F6000 D:\j2sdk1.4.0_01\jre\bin\awt.dll
0x777F0000 - 0x7780D000 C:\WINNT\System32\WINSPOOL.DRV
0x75DF0000 - 0x75E0A000 C:\WINNT\System32\IMM32.dll
0x77A40000 - 0x77B36000 C:\WINNT\system32\ole32.dll
0x6D180000 - 0x6D1D0000 D:\j2sdk1.4.0_01\jre\bin\fontmanager.dll
0x51000000 - 0x51044000 C:\WINNT\System32\DDRAW.dll
0x72810000 - 0x72816000 C:\WINNT\System32\DCIMAN32.dll
0x69000000 - 0x69125000 C:\WINNT\System32\ATIO2KAD.dll
0x77910000 - 0x77933000 C:\WINNT\system32\imagehlp.dll
0x72970000 - 0x7299D000 C:\WINNT\system32\DBGHELP.dll
0x68F30000 - 0x68F3B000 C:\WINNT\System32\PSAPI.DLL
Local Time = Tue Jun 11 11:38:25 2002
Elapsed Time = 1
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot Client VM (1.4.0_01-b03 mixed mode)
# An error report file has been saved as hs_err_pid1216.log.
# Please refer to the file for further information.
bitte helft mir, hab schon alles probiert, neuinstallation des JDK inkl. JRE eingeschlossen, classpath paramter gesetzt, wieder weggelassen etc.!
Thx
Stefan
public class Test
[/PHP]
versuch das ganze einmal ohne das semikolon ";" hinter der main-methode!
Hast du die Klasse "Test" in einem Packet abgelegt?
Wenn das so ist versuch mal in der Dosbox "java packetname.Klassenname"
Versuch es ansonsten mal unter JDK1.3 laufen zu lassen.
P.s.
DU SOLLST ARBEITEN!
Also mit JDK 1.3 funktioniert's. Bei mir zumindest. OK; er hängt sich auf, nachdem er das Fenster aufmacht, aber das Prog läuft. Hast es auch unter dem Klassennamen abgespeichert (Test.java)? Dumme Frage, ich weiss.
