Problem mit FreeBSD und ISDN
Ich versuche nun schon eine kleine Weile mein FreeBSD 5.1 dazu zu bringen sich über ISDN zu verbinden, aber es will und will einfach nicht klappen.
Meine Configdateien sehen wie folgt aus:
/etc/ppp/ppp.conf
default:
set log Phase LCP IPCP CCP Warning Error Alert
set device /dev/i4brbch0
set timeout 0
set dial
set login
set proctitle ppp-isdn
set speed sync
nat enable yes
enable dns
set ifaddr 10.0.0.1/0 10.0.0.2/0 255.255.255.0 0.0.0.0
add default HISADDR
set phone NUMBER_OF_PROVIDER
set authname USERNAME
set authkey PASSWORD
disable lqr
disable pred1 deflate mppe
/etc/isdn/isdnd.rc
# SYSTEM section: isdnd global configuration parameters
system
# accounting
acctall = on # generate info for everything
acctfile = /var/log/isdnd.acct # name & location of accounting file
useacctfile = yes # generate accouting info to file
isdntime = off
monitor-allowed = no
regexpr = "incoming call from"
regprog = incoming
rtprio = 25
entry
name = userppp
usrdevicename = rbch
usrdeviceunit = 0
isdncontroller = 0
isdnchannel = -1
local-phone-incoming = *
remote-phone-incoming = *
local-phone-dialout = YOUR_MSN
remote-phone-dialout = NUMBER_OF_PROVIDER
remdial-handling = first
dialin-reaction = ignore
direction = out
dialout-type = normal
b1protocol = hdlc
ratetype = 0
dialretries = 3
dialrandincr = on
recoverytime = 1
usedown = off
downtries = 2
downtime = 30
# EOF #########################################################################
In der rc.conf habe ich folgendes zu stehen:
isdn_enable="YES"
ppp_enable="NO" <-- damit ich ppp per Hand starten kann
ppp_mode="ddial"
ppp_profile="default"
Wenn ich nun "ppp" und dann "dial default" oder auch "dial" mache kommen folgende Meldungen:
Feb 28 16:37:49 defiant kernel: i4b: unit 0, assigned TEI = 66 = 042
Feb 28 16:37:49 defiant isdnd[205]: ERR set_channel_busy: controller [0] invalid channel [-1]!
i4b-L3 T303_timeout: SETUP not answered, cr = 118
i4b-L3 next_l3state: FSM illegal stat, state = ST_U0 - Null, event = EV_T303EXP - T303 timeout!
Wenn ich in der /etc/isdn/isdnd.rc dann den isdnchannel aufgrund der obigen Meldung auf "1" setze kommt folgende Meldung:
i4b-L3 T303_timeout: SETUP not answered, cr = 37
Ich verstehe diese Meldungen einfach nicht und wäre über jede Hilfe sehr dankbar.
mfg
hi
ja mit ISDN und FreeBSD ist so ne sache... hatte das gleiche problem, des liegt daran das man im i-net nur ppp anleitungen findet, für ISDN4BSD braucht man das eigentlich nicht, also vergiss ds mit dem ppp, leider habe ich im momet keinenen zugang zu meinem rechner sont könte ich hir die conf dateinen reinstellen, im prinzip gehts so, in den kernel ISDN unterstützung und eventuell firewall unterstützung einkompailiren (2 Zeilen).
dann die /etc/isdn/isdnd.rc anpassen (darin gibts ein paar häckchen)
und dann isdn_enable="YES" in der /etc/rc.conf und das wars.
man kann dan automatisch ins inet gehen oder per befehl.
ich mach das dann so,
einwählen:
ifconfig isp0 link1 up
und
verbindung trennen:
ifconfig isp0 down
ohne die config dateinen wirst du auch nicht weiter kommen aber ich stell sie mal die nächten tage hier rein.
sorry...:rolleyes:
