SWING Applikation actionPerformed Problem
Hallo!
Habe schon lange nichts mehr mit Java gemacht, habe es aber nun im Studium aufgebrummt bekommen und komme bei dieser Swing Applikation einfach nicht weiter:
import javax.swing.JFrame;
import javax.swing.JLabel;
import java.awt.*;
import javax.swing.JPanel;
import java.awt.event.ActionListener;
import java.awt.event.ActionEvent;
import javax.swing.JButton;
import javax.swing.JOptionPane;
import javax.swing.JComboBox;
import javax.swing.JTextField;
import java.util.ArrayList;
import java.util.Collections;
import java.util.Iterator;
import java.util.Vector;
public class Fenster extends JFrame implements ActionListener {
    Vector al = new Vector();
    JLabel label = new JLabel();
    JButton button = new JButton();
    JButton info = new JButton();
    JButton sort_button = new JButton();
    JButton shuffle = new JButton();
    JComboBox students = new JComboBox();
    JTextField name_text = new JTextField();
    JTextField perskz_text = new JTextField();
    JButton add_button = new JButton();
    public Fenster() {
        try {
            jbInit();
        } catch (Exception ex) {
            ex.printStackTrace();
        try {
            jbInit();
        } catch (Exception exception) {
            exception.printStackTrace();
    private void jbInit() throws Exception {
        getContentPane().setLayout(null);
        label.setFont(new java.awt.Font("Comic Sans MS", Font.PLAIN, 16));
        label.setForeground(Color.blue);
        label.setToolTipText("HI");
        label.setText("My First SWING Application");
        label.setBounds(new Rectangle(30, 23, 232, 30));
        button.setBounds(new Rectangle(18, 269, 110, 25));
        button.setActionCommand("exit_button");
        button.setText("Exit");
        info.setBounds(new Rectangle(161, 270, 110, 25));
        info.setToolTipText("");
        info.setActionCommand("info_button");
        info.setText("Information");
        sort_button.setBounds(new Rectangle(20, 208, 110, 25));
        sort_button.setActionCommand("sort_button");
        sort_button.setText("Sort List");
        shuffle.setBounds(new Rectangle(161, 209, 111, 25));
        shuffle.setActionCommand("shuffle_button");
        shuffle.setText("Shuffle List");
        students.setFont(new java.awt.Font("Comic Sans MS", Font.BOLD, 10));
        students.setActionCommand("studentscomboBoxChanged");
        students.setBounds(new Rectangle(7, 84, 276, 26));
        name_text.setText("Insert Name here");
        name_text.setBounds(new Rectangle(32, 121, 158, 25));
        perskz_text.setText("Insert Perskz here");
        perskz_text.setBounds(new Rectangle(32, 154, 157, 25));
        add_button.setBounds(new Rectangle(198, 141, 68, 22));
        add_button.setToolTipText("");
        add_button.setActionCommand("add_button");
        add_button.setText("Add");
        button.addActionListener(this);
        info.addActionListener(this);
        sort_button.addActionListener(this);
        shuffle.addActionListener(this);
        students.addActionListener(this);
        add_button.addActionListener(this);
        this.getContentPane().add(sort_button,null);
        this.getContentPane().add(shuffle,null);
        this.getContentPane().add(students,null);
        this.getContentPane().add(name_text,null);
        this.getContentPane().add(perskz_text,null);
        this.getContentPane().add(add_button,null);
        this.getContentPane().add(button,null);
        this.getContentPane().add(info,null);
        this.getContentPane().add(label,null);
    public void actionPerformed(ActionEvent e) {
        if (e.getActionCommand().equalsIgnoreCase("exit_button")) {
            JOptionPane.showMessageDialog(this, "EXIT BUTTON PRESSED");
          //  System.exit(0);
       if (e.getActionCommand().equalsIgnoreCase("info_button")) {
            JOptionPane.showMessageDialog(this, "JAVA Übungsbeispiel");
        if (e.getActionCommand().equalsIgnoreCase("add_button")) {
            System.out.println("ADD PRESSED");
        if (e.getActionCommand().equalsIgnoreCase("shuffle_button")) {
            System.out.println("Shuffling List");
    public static void main(String[] args) {
    Fenster f1 = new Fenster();
    f1.setSize(300, 350);
    f1.setTitle("SWING Window");
    f1.setResizable(true);
    f1.setVisible(true);
    f1.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
    Dimension screen = Toolkit.getDefaultToolkit().getScreenSize();
    f1.setLocation((screen.width - f1.getSize().width) / 2,
                   (screen.height - f1.getSize().height) / 2);
Das Problem: Bei mir wird die action performed methode immer doppelt aufgerufen!
Wenn ich den ADD Button drücke, dann ist die ausgabe:
ADD PRESSED
ADD PRESSED
Diese Ausgabe sollte aber bei einfachen Klick nur einmal kommen!!!
Arbeite mit dem JBuilder und Java 1.4
mfg
Hi!
Mach deine actionPerformed()-Methode mal folgendermaßen:
		//  System.exit(0);
	[B][I]else [/I][/B]if (e.getActionCommand().equalsIgnoreCase("info_button")) {
	[B][I]else [/I][/B]if (e.getActionCommand().equalsIgnoreCase("add_button")) {
	[B][I]else [/I][/B]if (e.getActionCommand().equalsIgnoreCase("shuffle_button")) {
Tipp: Du kannst übrigens auch auf die Verwendung von ActionCommands verzichten, wenn du willst. Das machst du zum Beispiel wie folgt:
	if (e.getSource() == sort_button ) {
	if (e.getSource() == add_button ) {
	// etc. ...
Die Methode getSource() des ActionEvent's liefert dir (wie der Methodenname schon sagt) das Quellobjekt bzw. den Auslöser des Events zurück. Das kannst du direkt mit deiner Objektreferenz vergleichen.
Aber das nur nebenbei...
Ach ja, es reicht übrigens vollkommen aus, wenn du die Methode jbInit() nur einmal im Konstruktor aufrufst... ;)
