19. August 200619 j Habe ein Problem mit meinem Sony Vaio FS115m. Und zwar läuft die ganze Zeit der Lüfter. Die CPU Temperatur ist unter CPU Cool 53°C bei normalem Internetbetrieb. Im Windows Task Manager unter Systemleistung läuft das Notebook miz 100% Rechenleistung bei normalen Internetbetrieb. Habe erst gestern das Notebook bekommen ( gebraucht - 1 Jahr alt) und direkt alles neu installiert. http://www.pictureupload.de/pictures/190806123803_sony.JPG
19. August 200619 j Im Windows Task Manager unter Systemleistung läuft das Notebook miz 100% Rechenleistung bei normalen Internetbetrieb. Dann solltest du dir mal die Spezifikationen von CPUCool anschauen, das ist durchaus korrekt so. CPUCooL Cooling Mode Under many operating systems like Windows NT and Linux the CPU issues an HALT operation when there is nothing to do. That enables a CPU build in functionality that reduces the power consumption. That keeps the CPU cool and saves money. If you overclock the CPU it is advisable to use such a program as the CPU gets hotter as specified. Unfortunately there is no HALT operation under Windows 95 / 98. The CPU permanently checks whether there is something to do or not. Many other programs like CPUCooL put in a task at low priority which issues a HALT instruction. But it costs time to make the new program run.You can see these programs work with the Microsoft WinTop Monitor. It shows 100 % activity although there is nothing to be done by the CPU. CPUCooL has an other technique to solve this problem. Look at WinTop and you see the difference. Wintop shows the normal idle time as before. CPUCooL integrates the HALT operation directly into Windows 95 / 98. The other advantage is that you can only switch off this cooling function by CPUCooL. There is no other way. Even if CPUCooL is terminated the cooling functionality is still alive! http://www.cpufsb.de/COOLING.HTM
19. August 200619 j Hab jetzt auch mal ne längere zeit cpu cool ausgestellt. der lüfter läuft trotzdem durch
19. August 200619 j Hast Du mal gecheckt ob vielleicht die Lüftungsschlitze eingestaubt sind? Kann ja auch nach einem Jahr schon passieren, wenn das Notebook in einer staubigen Umgebung genutzt wurde.
19. August 200619 j Die Luft wird meistens unten angesaugt und dann nach rechts, hinten oder links rausgeblasen. Einfach mal rundherum schauen ob es Lüftungsschlitze gibt, dort mit einer Taschenlampe reinleuchten und den eventuell dort hängenden Staub entfernen (entweder saugen, mit einem Pinsel rangehen oder das Gehäuse aufschrauben, wenn der Staub hartnäckig ist).
